Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
WACO YMF
Old 08-29-2014, 04:09 AM
  #17676
ceije
Bill, I seem to remember about the same situation i had with my wife except she was not savable. I do pray that you can and will be retreated to remission. to coin an old phrase -when the going gets tough, the tough get going. good luck and God's speed..
chris melhus
Old 08-31-2014, 09:51 AM
  #17677
ceije
Dan, have you made any headway on changes to clevis and arms as of yet or still working o he moving process which i know is long and drawn out.
regards
chris
Old 08-31-2014, 10:52 AM
  #17678
Jim Henley
Jinxx, Both Pica kits have a "front load" fuel tank. I suspect you may have a one of scratch build. Is the lower wing permanently attached? Both version of the Pica have removable lower wings. Sorry I can not give you more information.
Old 08-31-2014, 04:40 PM
  #17679
mrdhud
My Feedback: (48)
mrdhud's Avatar
regards
chris
Chris I've been busy working on the new old house no time for fun. Hopefully soon.
Old 08-31-2014, 09:19 PM
  #17680
Jinxx
The lower wing can be removed and provides access into the fuselage. I believe this plane was built from plans and not a kit but I don't know who's plans. By front load do you mean through the firewall? What would me the best way to access it in that case...cut through the firewall or try and cut in from the top of the fuselage?
Old 09-01-2014, 06:36 AM
  #17681
Jim Henley
I would remove the lower wing and if possible cut through the formers and remove the tank from the rear, rather than trying to cut a hole in the plywood firewall. Several of us have converted the Pica kit where the tank is accessible from the rear.
Then you can cut some pieces of lite ply or balsa, and reinforce the formers you cut, thus making the tank accessible in the future.
Old 09-01-2014, 08:12 AM
  #17682
Cougar429
Cougar429's Avatar
My 1/5 Pica did not have access to the tank through the firewall, perhaps built that way from the start. Everything was pulled out anyway to access the back when installing the 125 as different mount bolt pattern and due to repairs to the front of the firewall. At this time I replaced the tank and used plastic tubing for all the runs. Much easier to route and work with than brass.
I opted to build a retaining bulkhead into the servo tray, as it would be relatively easy to pull in one go, (the servos would be in the way otherwise). Since both wings come off for transport this is easily accessible.
ID:	2027798   Click image for larger version
Old 09-01-2014, 11:49 AM
  #17683
Jim Henley
The Pica as kitted used maple engine bearers that extend from behind the tank location through the firewall to mount the engine. This necessitated an upright engine mounting. You did as I did I built another plywood firewall and epoxied and screwed it to the original and to the maple mounts that had been cut off flush. I then opened up the formers to pass the tank through. I like the way you handled the servo mount as the plans/instructions don't give much information on where to place the servos,
pretty much leaves it to the builders imagination. Which is not a bad thing.
Old 09-09-2014, 01:17 PM
  #17684
hopkimf
My Feedback: (56)
Barth YMF 1/3
Paint job done.It's automotive with clearcoat over decals and paint. Only glitch was decals. I had two color and was going to pick up a roll of 1/8 red striping tape for wings and tail to separate the black and yellow before clearcoat.. But my painter called and told me he was putting decals down and was going to clearcoat and get it out that day. Time is money in bodyshop. So much for red with black over top. He had the black down when I got there. If this were a contest plane I would have a big issue. If it was a car body, sand it off and do it over. Not here. Another glitch came in N number position. not quite right. Other than that It does look good. N number comes from a full scale Bonanza. November One Charlie Echo. 'Nice' name.
Mike Hopkins
Waco Brotherhood # 132
Name:	C-G Paint 1.JPG
ID:	2030685   Click image for larger version
Name:	C-G Paint 2.JPG
ID:	2030686   Click image for larger version
ID:	2030687   Click image for larger version
ID:	2030688   Click image for larger version
ID:	2030690   Click image for larger version
Old 09-09-2014, 02:00 PM
  #17685
acerc
acerc's Avatar
Mike, why can't you apply the pin striping as is over the clear?
Old 09-09-2014, 04:01 PM
  #17686
hopkimf
My Feedback: (56)
acerc,
I guess I could. Easy enough to lay it on wings and tail. But with all the curves in cowl blisters and wheel pants, it looks like a tedious job. Plus all the letters on n number.
Mike Hopkins
Old 09-09-2014, 05:30 PM
  #17687
acerc
acerc's Avatar
Anything like this one???? Every where the color changed got gold around it, this was the start.....
Old 09-09-2014, 07:26 PM
  #17688
Zor
Banned
Default Comment
Mike,
It looks nice to me as is.
Perhaps a couple of black lines on the fin-rudder similar to the fuselage side would enhance the tail area.
Zor
Old 09-10-2014, 12:58 AM
  #17689
tmac48
tmac48's Avatar
Mike,when she is assembled I bet you will be more than happy with the end result. I believe that we do get a little anal at times when something does not go as planned.
Tmac
Old 09-11-2014, 02:01 PM
  #17690
hopkimf
My Feedback: (56)
YMF Barth 1/3
For cockpit combing I used 3/16 ID x 3/8 OD neoprene tubing 80 duro. I never could make a straight cut to split the tubing whether neoprene or vinyl. It was always snaking around and so forth. This time I slid a 3/16 steel rod all the way through the tubing with a couple inches sticking out. Then I put it on the band saw with the steel rod just touching the side of band saw blade. Using the blade as a guide I pushed it through until I had enough cut. Made a short practice run first. Worked slick and took off just enough so it slips on just like I hoped. Maybe I'm a slow learner and others have been doing this forever, but it did work well.
Mike Hopkins
ID:	2031219   Click image for larger version
ID:	2031220   Click image for larger version
Name:	neoprene cut 2.JPG
Old 09-18-2014, 04:13 AM
  #17691
Stickbuilder
Stickbuilder's Avatar
3rd surgical procedure is tomorrow morning at. 10:00. Y'all keep me in your thoughts and prayers. Oncology work will begin next week. Chemo and radiation. Wonder how I'll look bald.
Bill. Waco Brother #1
Old 09-18-2014, 05:03 AM
  #17692
skylarkmk1
skylarkmk1's Avatar
Bill,
Just remember "The Lord only made a few good looking heads, the rest he covered with hair." You are going to get better looking during the treatment.
Old 09-18-2014, 07:37 AM
  #17693
skypup50
Bill
My 8 1/2 year old daughter had ewing's carcoma and looked wonderful bald. She went through 2 surgeries and 2 forms of chemo, the second was experimental, and is now protocol, My daughter is 33 now and the mother of my 11 year old granddaughter. Here's wishing you a speedy recovery just like my daughter! You will be in my thoughts and prayers.
Old 09-18-2014, 07:42 AM
  #17694
Stickbuilder
Maybe when it grows back it won't have all the grey in it.
Bill, Waco Brother #1
Old 09-18-2014, 07:44 AM
  #17695
BobH
Good luck with everything. FYI I had chemo twice and never was bald. Depends on the chemo that you are given.
Old 09-18-2014, 01:46 PM
  #17696
tmac48
tmac48's Avatar
We must all be getting to that point of our life when our age starts to catch up to us. Have the wings masked out to paint the red with black pin stripe but waiting for surgery date to have this bloody back fixed so might not get the painting done in the near future.
tmac
Old 09-18-2014, 02:44 PM
  #17697
skypup50
Originally Posted by tmac48
We must all be getting to that point of our life when our age starts to catch up to us. Have the wings masked out to paint the red with black pin strip but waiting for surgery date to have this bloody back fixed so might not get the painting done in the near future.
tmac
LOL....I'm 64 and 2 surgeons told me I need back surgery too. They told me I wouldn't recover in time for my son's November wedding so the wait is on. Still need to start my 1/6 Waco.
Old 09-18-2014, 03:19 PM
  #17698
Jim Henley
We'll be thinking of you.
Old 09-18-2014, 06:06 PM
  #17699
lovehydro
My vary best wishes to Stickbuilder. I wish him a successful operation and a quick recovery.
I have been trying to receive a copy of his plans for the built up wings for the Byron STA. If someone has a copy of these plans I sure would like to purchase a copy.
Thanks, Paul
Old 09-20-2014, 02:59 AM
  #17700
tmac48
tmac48's Avatar
Yeh what he said Bill, get back to it pronto old boy.
tmac
