H Ray rib pattern
RE: H Ray rib pattern
I'll look for my plans as well.
Here's the rib scanned. The vertical one should print as is.
I scanned the ruler to make sure you get the right size.
The rib measures 1/32 shy of 7 and 1/2 inches long.
1 inch high at the spars.
From the plans.
Paul
From the plans.
Paul
Just in case the rib from the plan scan doesn't print to an accurate size, here's dimensions of the finished rib.
Outside max chord....8 and 3/4 inch
Max outside height....1 and 1/8 inch
pd1,
thanks for the measurements as they were printing too large.I redrew in cad and now nthe length is fine.any chance you could give the measurements of the spars,ply doublers,le,te so I can finish it off.I maybe able to use it for a cut file and have a set of ribs laser cut.
