Twin .020 Jr Skylark build thread
OK, I am going to build a Jr Skylark with twin .020's - R, E, A, no throttle. This should be interesting. I could have put this in any number of forums, but since I will be doing a silk & dope finish, I figured Antique is the proper place.
RE: Twin .020 Jr Skylark build thread
First, I will do the body halves. Nice laser cutting from Early Models, the joint fits perfectly. I was concered about the outer part of the joint not sanding smooth if I used a hard glue, so what I did was just wiped the inside of the joint with thick CA. Any gap on the outside will be filled when I sand and dope it. I am not concerned with strength since this joint will be overlaid with another sheet of balsa doubler.
So next are the forward doubler, tail one, and the wing tripler. All are attached with 20-minute epoxy, spread VERY THIN. No need to add weight, just stick the stuff together. Another plus for Early RC models, the parts line up perfectly. And, the balsa is acceptably light.
So now I can install the upper triangle stock that makes the body rounded. Here I must use Ambroid, because it sands really good, and, well, this is an antique build! Of course, you have to double-glue the joints, which means smearing glue on each surface and letting it dry. This drive the glue into the grain, and makes a stronger joint. Then, when you actually glue it the second time, it softens the first layer, and lets the glue bond deeply into the wood. You know the second layer is thick enough when the glue just about oozes out of the joint.
Last post for tonight - The two formers that box the wing are installed, making sure they are 90 degrees to the sides. I will have to now make a mirror image for the other side, then join them, In a day or two, I figure, stay posted!!!
Rock on!!!....I always wanted to see if this was a doable project. TDs or reed .020s? I love the lines of the Skylark.
SC
That's going to be great! I have the same kit, but I think I'm going electric. I do have the OS .15 powered Skylark 56 twin you saw at Octoberfest - I plan on having them both at the Mid-South VRCS fly-in in May 2009; are you going? Russ Farris
Damn, FB, you're fast. I have another 3 or 4 posts to do today!
_____________________________
Pilot dog FTW!
Pilot dog FTW!
FB
Watching your build thread! I am just beginning to restore one that has been in an attic for about 40 years. Are you going with the original dihedral or removing some?
I built one of these many years ago. I used the dehidrel as per the plans and two Cox TD .010 motors. The radio was a Cannon two channel block and another servo for ailerons. Flew great even with one engine out. I would love to have a set of plans to build another. I still have the motors in storage. Lost the plane when I let a friend fly it and he crashed into a tall tree. Landing was just fine but getting it down did it in. Enjoy and keep us posted. Would love to have a set of plans if you decide to scan them.
MN
http://my.pclink.com/~dfritzke/jrskylark.pdf
(Incorrectly noted in FEB. 2009 Flying Models as www.my.pclink.com/%7Edfritzke/)
Dave
Dave
ON, CANADA
1 Post
Highplains,
The motors are 400XT from Hobby lobby. I am using 2 ESC's with 1 3S 2200 mah lipo.
Great little outrunners with 7X6 props (8X6 cut down)
Note that the plane was increased by 10% overall. New WS is 42".
Overall weight ready to fly 27 oz.
