Top Flite DC-3 wing joining
NJ
I have gotten to step 2 under Joining outer panels to center section wing. I can't locate the 1/16" ply top spar joiners the 1/16" ply bottom spar joiner or the 1/8" ply t/e joiner. I looked through all of the die cut sheets and the hardwood bag and the parts list but I can't locate these parts. Thanks for your help. Deltatech
RE: Top Flite DC-3 wing joining
It looks like the pieces you need are the triangular-shaped pieces in the upper-left-hand corcer of DC3TS08. They join the outboard spars with the center spars. They are semi-triangular because the spars come together at an angle. If you lay them over the plans, you'll see how they fit. Apparently, though, they never made it onto the plan drawings, though.
