GP Cub 60 Float attachment
My Feedback: (80)
Im currently building GP 60 size floats for the GP 60 size cub. the float manual covers how to attach the rear float attachment but does not cover how to attach the forward float attachment to the fuselage. Should I mount it the same as the rear and drill more holes in the plywood landing gear mount plate? Or is there a way to utilize the holes that the aluminum gear mounts to and plug the other holes that do not get used to keep water out of the fuse? any and all suggestions are appreciated
RE: GP Cub 60 Float attachment
You would use whatever's handy. If you can use the existing gear plate, then do so. A lot of guys will use the regular landing gear and just take off the wheels. Then the struts are located on the float so that the step is a hair aft of the model's balance point.
