How do you take Shaft out of the AXE
How do you take Shaft out of the AXE ?
I finally got the main bolt out that holds the center hub. How do I get the main shaft out. Is everyone taking the frame apart. It seems that there are some bushings or something holding it in. Please help !!
CA
RE: How do you take Shaft out of the AXE
ORIGINAL: Heli Bat
Just a suggestion before you remove each part, take a digi photo of each parts connected together. That way if you have forgotten how they look like assembled, then you can always use the photos as reference to make comparisons and see if what you are doing are proper and correct.
Refer to the pictures attached:
Here's the four (4) things you need to remove.
http://www2.towerhobbies.com/cgi-bin...?&I=LXNWG2&P=Z
http://www2.towerhobbies.com/cgi-bin...?&I=LXNWK4&P=Z
http://www2.towerhobbies.com/cgi-bin...?&I=LXNWJ4&P=Z
http://www2.towerhobbies.com/cgi-bin...?&I=LXNWJ3&P=Z
Good luck and I hope this info helps out.
Thank you Thank you
I have found that now, I have a severly bent feathering shaft that runs thru the center hub - maybe the source of all the wobbling.
Heli Bat
Heli Bat
