Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Helimax
 AXE CP learning issue >
Helimax This is for all your Helimax questions and comments.
Old 03-10-2007 | 08:38 PM
Default AXE CP learning issue
Hi am new to learning helicopter flight and picked up the AXE CP. I read Rudd's instructions and am up to battery 3 and 4. I notice the tail rudder only spins when I apply move the right stick right. This makes following his steps pretty tough. I also noticed when I start applying more head spead the heli shakes like crazy. Any advice here would help.
Old 03-10-2007 | 10:38 PM
Heliko's Avatar
Default RE: AXE CP learning issue
ORIGINAL: half31
That's normal. Tail motor helis use a fixed pitch tail rotor. On the Axe this means when you apply left rudder the tail motor decreases or on hard left rudder will stop completely. The heli relies on the torque of the main rotor to nose left.
Are your blades tracking correctly? If so it sounds like your rotorhead is out of balance. Even though the Axe it's supposed to come balanced and trimmed out it's not. You have to balance the blades and the rotorhead.
