Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Helimax
 Axe CP Feathering Spindle Upgrade Kit >
Helimax This is for all your Helimax questions and comments.
Old 04-10-2007 | 07:20 PM
Scalegraphix's Avatar
Default Axe CP Feathering Spindle Upgrade Kit
Just found this on the Heli-Max Site: [link=http://www.helimax-rc.com/techsupport/hmxe04tech2.html]Axe CP Upgrade[/link] And it's FREE!!
Old 04-10-2007 | 07:26 PM
Default RE: Axe CP Feathering Spindle Upgrade Kit
Kool .. thx for the heads up
Old 04-10-2007 | 08:11 PM
BoysToys's Avatar
Thanks for the heads up! I just emailed about getting the replacement part. We will see how long it takes for them to respond and send out the "upgrade" parts.
Old 04-10-2007 | 08:28 PM
ORIGINAL: BoysToys
Same here. I have heard that they have pretty good customer service from others.
Old 04-11-2007 | 10:48 AM
StrykerIncognito's Avatar
I emailed them yesterday, and the reply today was they're already out of stock.. that they would send me a kit as soon as they're available.
Not that I REALLY need it right now, but it will be a nice change from fighting with the darn near stripped out phillips heads instead.
Old 04-11-2007 | 07:56 PM
ORIGINAL: strtykrincognito
I got the same responce via email today myself.
Old 04-11-2007 | 08:53 PM
Ditto, they said they will be available by the end of April.
Old 04-11-2007 | 09:49 PM
email and waiting hm wonder how fast they ship?
Old 04-22-2007 | 01:55 PM
SchoooBaka's Avatar
Email sent.
Thanks for the info!
Old 04-22-2007 | 07:04 PM
no reply from them boo.
Old 04-22-2007 | 10:40 PM
SchoooBaka's Avatar
I got a reply! [sm=regular_smile.gif]
Say's they're on back order.
They'll send me the kit when they come on.
[sm=thumbs_up.gif]
Old 04-23-2007 | 08:32 AM
second email sent will see what happens
Old 04-25-2007 | 12:19 PM
Good news .. i received my upgrade today in the US Mail # HMXE7814
Not bad for HM .. Talked to someone on 4-11 and now its 4-25 and just got it
Old 04-25-2007 | 01:52 PM
thestratcat's Avatar
My Feedback: (12)
wow!! I'm absolutely amazed!!!
the heli that was in at heli-max came back with the upgrade, and I recieved the upgrade for my other heli in the mail this morning.
Old 04-25-2007 | 02:34 PM
PilotLight's Avatar
Its probably a liablility issue and they want them upgraded asap to prevent injury.
Old 04-25-2007 | 02:43 PM
i had a blade come off in in flight ..blade grip was still attached to the blade when i found it .. broke the head of the screw off
Old 04-25-2007 | 04:56 PM
Heliko's Avatar
Got my spindle kit today. They're using cap screws so I'm not sure they'll allow the blades to fold forward. I did find [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=001309151&I=LXLBR0&P=K]these screws[/link] at TH, but they're 1mm shorter and require a 1.27mm allen wrench. I went with [link=http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXKTH7]Integy .05" drivers[/link] after I found that .05" was the same size as 1.27mm. I haven't received this stuff yet so I can't be positive it will work. Another option for screws is [link=http://www.rcgroups.com/forums/showpost.php?p=7324950&postcount=2049]here[/link]. This guy went threw alot of trouble to find strong screws that would work, and he had to order a minimum of 100 so he has a few extra. I bought 6 off him.
Old 04-25-2007 | 05:00 PM
My Feedback: (12)
Heliko - the new screws just barely caught the squared corner of the blades, I went ahead and gently forced them to move, then took them off and superglued where I'd ripped the skin/wood to seal things up, I haven't had any problems..
Old 04-25-2007 | 06:15 PM
Heliko's Avatar
I know you can force the blade forward past screwhead with a just little bit of force Stratcat. In fact my blades have been on the heli for a while and some minor crashes have folded them forward and took off a little monokote like you said, but I'd prefer the blades not to contact the screwheads if I can help it.
Old 04-28-2007 | 10:02 PM
BoysToys's Avatar
My upgrade kit just arrived yesterday. Question: Can you use the hex screws with the old feathering shaft or do you have to use the hex bolts with the new shaft? I don't plan on doing anything until I break another blade grip. Thanks!
Old 04-29-2007 | 06:24 AM
ORIGINAL: BoysToys
Im curious about that as well, it might be a different thread, thats why they sent the new shaft. Im gonna check and see.
Old 04-29-2007 | 08:41 AM
markconsig's Avatar
I bent my new feathering spindle the day i got it! put the old one in with the new hex screws and it seems to fly fine.
Old 04-29-2007 | 01:32 PM
Heliko's Avatar
I think the reason they sent a new spindle along with the capscrews is that when the screws failed the heads would break off, but the threaded portion of the screw remained in the spindle. If that happened it would be near impossible to remove it from the spindle especially with Loctite.
Old 04-29-2007 | 03:16 PM
Man this is great! And its Free!!!!
