Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Helimax
 HELIMAX PRO SETUP ISSUE !! >
Helimax This is for all your Helimax questions and comments.
Old 04-28-2007 | 08:54 PM
Default HELIMAX PRO SETUP ISSUE !!
Today i started putting togather my helimax pro, I am having an issue that is sort of puzzling to me. The problem is when i start the motor only the large gear rotate, the main blades and the tail blades do not move at all, can somebody tell me what is happening here, this is frustrating, appreciate any input please.
Old 04-28-2007 | 09:05 PM
Heliko's Avatar
Default RE: HELIMAX PRO SETUP ISSUE !!
I don't have that heli, but it sounds to me like the main gear is upside down, or the one-way bearing has been installed upside down. If the maingear came with the bearing pre-installed pull the gear out, flip it over, and re-install it.
The bearing allows the rotor system to keep rotating if the motor fails or is shut off. This is what make auto-rotations possible.
Old 04-28-2007 | 09:08 PM
ORIGINAL: Heliko
I don't have that heli, but it sounds to me like the main gear is upside down, or the one-way bearing has been installed upside down. If the maingear came with the bearing pre-installed pull the gear out, flip the it over, and re-install it.
...or alternatively, both are in the right way but the motor is turning the wrong direction.
Old 04-28-2007 | 09:10 PM
Heliko's Avatar
ORIGINAL: osterizer
Oooo, good point that seems likely especially if it came at least partially assembled.
Looking down from above the main gear should be going clockwise.
Old 04-28-2007 | 09:11 PM
I AM GOING TO CHECK THESE ITEMS RIGHT AWAY GUYS, THANKS.
