Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Helimax
 AXE CP wiring question, ESC programming??? >
Helimax This is for all your Helimax questions and comments.
Old 10-11-2007 | 09:05 PM
Default AXE CP wiring question, ESC programming???
I had to buy an e-board because mine fried out. Failed to take a good luck at the wiring can someone snap me a picture and post it so I can see how the wires go? at least the gyro wire, and is there a procedure for setting the throttle points or anything on this board?
I plugged it the way I thought it all went, the only question I had was the gyro but it seems to be working ok. The problem is that I can't get the heli to throttle the way it should. It will not come on sometimes and then others it will jump on go to like 3/4 and then be stuck there. Its not the idle up switch, it runs the same way in both modes.
I never removed the top two servo leads, the other two I am concerned about. Someone snap me a pic or gimme some info plz
Old 10-12-2007 | 09:28 AM
Default RE: AXE CP wiring question, ESC programming???
ORIGINAL: redvtr1000
Here you go.
File Type: jpg
