Helimax This is for all your Helimax questions and comments.
Idle Up
Old 10-12-2007 | 07:27 PM
Cyclic Hardover's Avatar
Default Idle Up
What the heck is this for? Full speed or nothing.
Old 10-12-2007 | 07:45 PM
thestratcat's Avatar
My Feedback: (12)
Default RE: Idle Up
it brings your speed to a constant so you can then use the positive/negative pitch of the rotor blades to control movement..
DISCONNECT THE MOTOR!!!
then turn everything on and plug it in.. look what happens to your swash when you click that button to idle up, I believe it moves up the shaft to allow the +/- of the rotor blades.
Old 10-12-2007 | 07:52 PM
Default RE: Idle Up
StratCat's on the right heading. Idle-up is curved to try and keep the rotor speed constant, and it also changes the pitch curve, usually so you have equal positive and negative pitch available. It's normally used for aerobatics, but higher-end radios have more than one idle-up position. I use mine with normal for hovering and general cruising around, idle-1 for faster, more fun stuff, and idle-2 for full-up aerobatics.
Old 10-12-2007 | 08:26 PM
My Feedback: (12)
Default RE: Idle Up
hey man, I was eating, typing and putting a battery pack in the MX... cut me a bit of slack, I got the point across
(I knew someone would do it better than I did also..)
Old 10-12-2007 | 08:43 PM
Default RE: Idle Up
So basically, I won't be using this for quite a while.
Old 10-12-2007 | 11:28 PM
Default RE: Idle Up
Dude, I was just adding, not replacing .
CH-- Here's a test: if you fly regularly, and parts on your heli are less than two weeks old, then don't worry about it right now .
ORIGINAL: thestratcat
