Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Helimax
 Soft throttle up question >
Helimax This is for all your Helimax questions and comments.
Old 11-06-2007 | 05:56 PM
Default Soft throttle up question
I think someone posted that they had their TX set up to do a soft throttle up transition from off to idle up - they could switch idle up on and it would slowly spin up to idle up speed. Did I read that correctly, and can it be done on the 7CHP?
Old 11-07-2007 | 08:44 AM
thestratcat's Avatar
My Feedback: (12)
Default RE: Soft throttle up question
I think that's an ESC setting instead of a transmitter setting.
I tried it when I built the t-rex, it lasted about a day, I absolutely couldn't stand that soft startup! I thought it was cool on startup, but the problem I didn't like was when you cut the throttle, it starts slowly again.. so, when I panick, cut the throttle a touch too much, I'm stuck doing a soft start to regain the heli... I didn't like that.. but try it for yourself.
Old 11-07-2007 | 09:30 AM
I kinda feel the same way stratcat.
Old 11-07-2007 | 04:13 PM
I'm pretty sure the poster said they had programmed their radio that when they flipped into idle up, instead of instant head speed it would take a second or two to come up to speed - don't recall mentioning an ESC.
Old 11-07-2007 | 10:55 PM
Soft start is a function of the ESC, not the transmitter, sorry. As for losing it in flight, if you're using a soft start, you really should switch to an idle-up curve so you can't cut it by accident.
Old 11-11-2007 | 09:56 PM
AirmanBob's Avatar
My Feedback: (14)
I've got the soft start function set up on my ESC.
It only soft starts if you move the throttle SLOWLY
up.
IF, when I'm decending the heli at a fast rate and I
want to slow it down....I move the throttle up faster
and further and the motor speeds up just fine.
So basically...the slow start feature is really not a
handicap as some seem to think.
Slow start sure saves wear and tear on the main
gear and the rotor head assembly in my opinion.
AB
