SHUTTLE AND EVO BELTS
Hello
I have a 30 size Shuttle and want to extend the tail for scale a 60 size fusealge . I was told that all I need to do was replace the boom
and belt with A 30 size Sceadu EVO belt and tail boom. I purchased the booms and used belts but I believe the belts are wrong. The groves on the ones I received are to close together for the gearing... Isn't the belt grove spacing the same on both the shuttle and the evo and just the EVO belt is longer? Thanks
I just compared my Shuttle ZX belt with the Sceadu Evo 50 belt and they are totally different. The Sceadu evo 30 is virtually the same as the 50 although the boom lengths may differ.( not sure without looking at a parts break down.) The ZX has larger teeth spaced farther apart vs the Evo that has fine teeth close together.
