Throttle limiter Royal Evo 9
I have a Royal Evo 9. Is it possible to work with "Throttle limiter" in the plane program as in helicopter?
I have an electric plane with a 3sLiPo that I would like to fly with 75% throttle so that the amps keep in the normal range of the motor (30amp), but I also would like to have the possibility in an emergency to have the option of 100% throttle (40 amps). The Esc is 40 amps and the battery can stand 60amps. So the motor is the bottleneck. The motor as enough power to cruise, so this is only for an emergency.
Thanks.
Thanks.
