Receiver for Eclipse 7
I’m a newbie and building my first plane(Kadet Mark ll) I was given a Eclipse 7 (72MHz) but I don’t have a receiver or servos. Can these still be purchased for this radio? What do ya all recommend and where would I find what I need. Thank you
I don't usually answer post 1 questions like this since they are often trolls but in this case I'm making an exception since you can get a lot of misleading answers. As a newbie the first thing you need to know is that 72MHz has transmitter/receiver frequency channel pairing unlike 2.4GHz. So you need to get a 72MHz receiver that is the same channel as your transmitter. And yes there are plenty of 72MHz receivers around. The transmitter channel is usually given with a sticker on the front or back of the unit. The Eclipse 7 can also use a SPECTRA module in the transmitter bay with allows you select the channel you want. Check to see if you have that - it will improve you ability to find a low cost receiver.
As far as receivers go, the Eclipse uses Hitec, Futaba, JR and Airtronics receivers - read your manual well on the frequency shift function. Also, it will only use stand PPM {AKA FM receivers} not PCM receivers. I suggest using 7 channel receivers. Hobby King has a selection of them including some off brand Futaba compatible receivers. Again, you must make sure to get the correct channel.
Thank you for the information, yes my tx has the Hitec synthesized spectra module which has two small dials on the side. Are these dials used to change the channels to match the rx?
Thanks again for your help. Larry
Spectra 2.4GHz Module with 2 Optima 6Ch 2.4GHz Rx by Hitec RCD Inc.
Spectra2.4Manual_EN_v3.pdf
