Really Dumb Question
PA
I am replacing some stripped gears in a couple of HS-300 servo's and the LHS doesn't/didn't have servo grease. I was told that I can use Vaseline instead.
Is Vaseline ok to use or is there something better if the "servo grease" is not available?
RE: Really Dumb Question
Vaseline will break down over time and get very fluid that can seem into areas you don't want it. It is best to use a white lithium based grease.
Mike.
Mike.
