help with servo question on HS625MG
My Feedback: (37)
WI
I ordered a set of four Hitec HS625MG servos from Tower last week. One pair will be used for ailerons and one pair for elevators in my extreme flight YAK54. My question pertains to one of the servos, which appears different than the other three.
The one servo in question came with a different set of control horns (they were the hardened Karbonite ones) as opposed to the standard white plastic. In addition, that one servo had black/red/yellow wires as opposed to black/red/white like the other three. All the servos said "Hitec HS625MG" on them. I just want to make sure that they are all the same servos. Maybe one is a newer version or lot number. The reason I want to make absolutely sure they are the same is because they are being installed in pairs on my plane (whether it be in pairs of ailerons or pairs of elevators). Thanks.
