Eclipse 7 mixes
My Feedback: (16)
TX
I have been having problems setting up mixes on an Eclipse 7 Q-PCM Tx...
Last night I tried to setup mixes on a new airplane with two elevator servos... Simple, straightforward, nothing fancy... Set one up as the master, one as the slave, EPA = 100% on both... The slave servo ALWAYS lags behind the master through full travel and 100% deflection on each servo is different... Plus, when I adjusted the digital trim for the elevator on channel 2, the mixed channel just sat there, doing nothing...
What's the deal???
Mark
What's the deal???
Mark
well if i may jump in .the eclipse 7 does not support mixing for dual elevators.you will need to use a reversing y for this if you want them to work the same and have trims on both sides
My Feedback: (19)
FL
Torqued-Up,
This is one of the faults that I also discovered in an otherwise fine transmitter. The Optic 6 has the dual elevator capability, but you do lose the extra channel and some of the mixes. I have not been a fan of servo reversing Y harnesses having had two failures. On my UCD 60 I used a standard Y harness and reversed one of my HS 635HB servos (very easy to do). The elevator has worked perfectly ever since. There are other ways around this problem, such as using one different brand of servo on one side that rotates in the opposite direction. Unfortunately running separate elevator channels is impossible with the E7.
My Feedback: (16)
TX
It would have been nice to hear this from a Hitec rep, but alas, it appears that they will not admit their own shortcomings...
It also appears that we cannot use the Eclipse 7 for for anything beyond basic setups... It would be nice to be able to mix channels for dual elevator, aileron servos to avoid the extra cost of Y-cables... Plus the fact that you cannot set deflection differential when using a Y-cable on the ailerons... The biggest pain is the fact that when you DO mix channels, there is always a noticeable lag in activation of the mixed channel... Plus the mixed channel does not travel to full deflection as the master channel does...
I do like the E7 for the fact that the spectra module allows you to switch Tx frequencies at will, avoiding channel conflicts with other flyers... But it now appears that I need to start moving my more complex programming issues to my 10X...
Thanks for the replies and happy flying...
My Feedback: (19)
FL
I never used a Y Harness for the ailerons except for a trainer. I use channels 1 and 6 and activate the flaperon function. I am just careful not to deploy the flap control unless I want to use it. I have also played with the differentials using end point adjustments that can be set individually up or down on each aileron servo. This is a manufacturers forum and we are really not supposed to air our comments. I have known about the elevator problem for some time, but that didn't stop me from buying another new E7. Realistically it is alot of transmitter for the money. I don't believe that Hitec will ever remedy this though as the Optic 6 and Multiplexes have the capability. I have aired this issue directly to Hitec myself some time ago. It is just a shame that the "Flagship" transmitter does not have this function[
]. Your lack of direct response may be due to the recent show schedules. I know that almost all of the large manufacturers are already on the way to Toledo Ohio. I wanted to order a new plane over the weekend, but was asked to wait until April 2, when everyone is back from Toledo. Fortunately my friend is going there and will bring it back for me if one is available at the show. I hope the moral support helps.
My Feedback: (31)
ORIGINAL: Torqued-Up
Also be careful with the volume control knob while utilizing the mix driving the elevators in this scenario as it can and will affect the implementation of dual elevator servos.
