Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Eclipse7 and dual rates
Old 10-09-2002 | 09:32 PM
My Feedback: (17)
Default Eclipse7 and dual rates
Hi Mike,
First off, I love my Eclipse.
I am, unfortunately, having some difficulty with the dual-rate switches. I set up the aileron and elevators switches, back = 50%, forward = 100%. All seems fine. But then I go to use the dual rates and sometimes the settings "stick".
For example. Turn on radio w/ switches back, ground check my airplane, switch the aileron dual rate switch forward (100%), but it doesn't "take". Throws stay at 50%. Hmmmm.... play with the sticks some more, toggle the Ail DR switch a couple times and voila.... now DR works as advertised. I would assume I have a bad DR switch, but it happens on all 3 DR channels (Ail, Ele, Rud).
1- Am I the only person seeing this?
2- Is this somehow user error? (wouldn't be the 1st time I messed up)
Thanks for your impressive customer service.
- Dave Majchrzak
Old 10-09-2002 | 10:06 PM
Very curious!
Haven't heard that one before. I suggest you clear another model memory and start from scratch programming in your plane, then see if the same thing occurs. If it does, I guess we need that Tx back so our crack service department can fix it up for you.
Old 10-10-2002 | 12:19 AM
JohnBuckner's Avatar
Default Same problem
Same problem with the exception it is occurs on the aileron and rudder channel. Discovered this morning, on checking the DR screen I could not set or change the curser from high to low but still functions for the elevator channel. I am using 'V' mix for Q-500 but have not experianced this with four other racers. I willsend the unit back as soon as possible.
thanks
John
Old 10-10-2002 | 05:35 PM
Default A little update
Used the radio this morning agine and the problem is definately intermittant. Yesterday I could only access elevator DR but today with no programing changes the aileron DR was functioning but the rudder DR is still is not switching.
John
Old 10-10-2002 | 05:53 PM
MikeMayberry's Avatar
Yes send that puppy back to us for evaluation.
Hitec Service
12115 Paine St.
Poway, CA 92064
Include a description of the issue and return address.
Glen
Old 10-24-2002 | 12:32 AM
Default Embarassed to Say
The non fuctioning rudder rate switch on my eclipse has been resolved happily and it was my fault. Good thing I did some more checking before packing it up. Being a heavy Prism 7 user a bunch of my pylon ships are on the Prism's and only two on the Eclipse, well in the heat of a forced change to a backup in mid event which was on the eclipse, I had brain fade with the two radios having rudder rate in entirely different positions. Also the apparent intermitant aileron rate loss was a result of confussion under pressure and a simple misplacement of the curser.
This may be a similar situation to Daves problem above. At any rate (pun intended) all is right with the world and I have sent some 555's back for repair, I still fantasize about getting through a race season without loseing a ship.
John
