EPA and elevon mixing,
I have a Hitec Flash 5 SX and a 555 RX. I was trying to limit servo travel, I'm using 2 HS-81 servo's in channel 1 and 2 with elevon mixing on. When I set all channel EPA's to 60% I see the travel is not the same for each servo. What am I doing wrong?
Rick O,
Rick O,
My Feedback: (31)
Rick
Did you employ trim at neutral to center the servos? If so this the likely culprit... The TRIm offset deviation affects the throw in either direction. Simply increase or decrease the EPA percentage in either direction to equalize the two surfaces.
