Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Dual elevator servos and aileron diff?
Old 06-24-2007 | 11:29 AM
Default Dual elevator servos and aileron diff?
When i have the ailevator active it says to use CH 2 and 5.The ailerons require CH 1 and 5 also with differential active.Do i plug the left aileron into CH 6? because i tried and it works like a flap? what am i doing wrong?I would like to run dual elevator servos on seperate channels and also my ailerons.I am using the Optic 6
Dan
Old 03-25-2012 | 04:04 PM
Default RE: Dual elevator servos and aileron diff?
I know it's been five years since your post, but was wondering if you ever got an answer. I'm in the same situation because I'm using a 7 channel reciever with my 9C. Please reply if you can help or want more information.
Old 03-25-2012 | 05:14 PM
<span style="font-size: smaller">ORIGINAL: Stik-n-Rdr I know it's been five years since your post, but was wondering if you ever got an answer. I'm in the same situation because I'm using a 7 channel reciever with my 9C. Please reply if you can help or want more information. Thanks,</span>
OP relates to an Optic 6 which has very different internal mix facilities to a Futaba 9c.
Using a Hitec Spectra module and a Hitec Optima 7 transceiver in a Futaba 9C relates
to the RF output only, channel mixing remains within in the Tx menu.
For correct information on programming a 9C, please refer to the Futaba forum:
http://www.rcuniverse.com/forum/forumid_125/tt.htm
Otherwise if "9c" was a typo, the following will assist:
. Hitec Eclipse &amp; Eclipse 7 Pro - All Manuals, Addenda,
Quick Setup, CCPM and Additional Programming FAQ</p>
. Hitec Optic 6 &amp; Optic 6 Sport - Manuals, Tutorial,
Comparison Charts, Updates &amp; FAQ
Alan T.
Alan's Hobby, Model &amp; RC FAQ Web Links</p>
Old 03-25-2012 | 05:25 PM
I didn't consider checking Futaba's forum, but will post the question there if I don't find anything. I also didn't realize I was replying to someone posting in the Hitec form, so apologize. Thanks for the quick response too.
Bye
