Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Optic 6 Spectra Module Problems
Old 03-05-2008 | 10:48 PM
Default Optic 6 Spectra Module Problems
I have had my Optic 6 with Spectra Module for a couple of years (right around two) and now I am experiencing the issue I have read about in the forums.
I will turn on the radio, switch on the plane and...nothing. It is on the correct channel so it was driving me crazy.
I removed the Spectra module, slightly bent down the wires exiting the back of the transmitter and then replaced the module. Viola I then had contact with the plane.
This has repeated twice now and now I cannot trust this radio to fly my planes.
Luckily I have an Exclipse 7 I can use but it doesn't have enough memory spots for all of my planes.
Can this be fixed? What is causing this issue? It doesn't seem safe at all.
Gary B
Old 03-06-2008 | 01:13 PM
MikeMayberry's Avatar
Default RE: Optic 6 Spectra Module Problems
Gary,
Sorry to hear about the problem. Send it in and we will do whatever it takes to get it working properly.
Here's the info: http://www.hitecrcd.com/Support/service%20form.pdf
Mike.
Old 03-06-2008 | 02:41 PM
Hi Mike,
Thank you for the quick reply. I will get this in asap.
Thanks again.
Gary B
Old 03-27-2008 | 11:29 AM
Just a note to Thank Hitec for such a quick turn-around. The radio was fixed (replaced) and sent back within a week.
Awesome service and kudos to Hitec!
Gary B
