Optima RX and HV servos
I'm going to venture into the HV realm on my next plane and will start off using the 5495BH servos, 2S Lipo and an Optima series receiver, either a 6 or 7.
What is the best way to wire this for a glow powered plane? A) 7.4V directly to the BAT/servo port B) 7.4V -> regulator to X voltage - > BAT port C) Pull SPC jumper and go 7.4V ->Y -> SPC & BAT D)or? Thanks in advance! |
RE: Optima RX and HV servos
[quote ]ORIGINAL: Hemikiller I'm going to venture into the HV realm on my next plane and will start off using the 5495BH servos, 2S Lipo and an Optima series receiver, either a 6 or 7.
What is the best way to wire this for a glow powered plane? A) 7.4V directly to the BAT/servo port B) 7.4V -> regulator to X voltage - > BAT port C) Pull SPC jumper and go 7.4V ->Y -> SPC & BAT D)or? Thanks in advance! [/quote] answered: Optima Transceiver (RX) - Battery set up for Nitro/Gas models following may also assist: Optima Transceiver (RX) - Battery set up for Nitro/Gas models<font size="1"> - caution re NiMH & Alert re LiFE.</font> Optima Transceiver (RX) - Dual or Multiple Batteries may be installed - Avoid Brownout & Add Redundancy, <font size="1">even one for each servo.</font> Alan T. |
ORIGINAL: Hemikiller I'm going to venture into the HV realm on my next plane and will start off using the 5495BH servos, 2S Lipo and an Optima series receiver, either a 6 or 7. What is the best way to wire this for a glow powered plane? A) 7.4V directly to the BAT/servo port B) 7.4V -> regulator to X voltage - > BAT port C) Pull SPC jumper and go 7.4V ->Y -> SPC & BAT D)or? Thanks in advance! |
