PICS OF YOUR SAVAGES !!
#5826
RE: PICS OF YOUR SAVAGES !!
JUSTPASSEDU if you want to start low you just have to install the IRC lower shock mounts upside down like in this picture. Hope that helps.
#5827
My Feedback: (20)
NY
Thanks you sportsfan i just may give it a try if i decide to install them , appreciate it , does it ride allot better like that ? what are your impressions? Thanks
#5829
juat thought i would post a few pics of my savage with my newly painted shell and new on road tyres before i took it out and it got wrecked
its not the clearest in the pics but its flicked paint its gold to purple with all the colours inbetween
#5830
my flux 5t conversion by tcscrawlers.com
main upgrades is rear hub carriers by integy, dx3s radio, cen genesis tires with 23mm hubs, and hd drive gear
running 17/44 and extended axles off the 5.9 savage. since the pic i build a tray inside the tvps for the batteries, and took the boxes off the sides. added a little more weight which worried me cuz its pretty heavy already. also thinking about making a skid plate for the bottom but not sure the added weight is worth it.
#5831
@ wolfie1... That paint job is SWEET. Ilike it. NIce work.I have the same motor in my Sav XL. Are you still running the 3-spd tranny? If so, how isit still functioning?I stripped the idle gear and broke a few teeth on the drive gear in my 3-spd after only about a quart of fuel thru the LRP. HPI sent me new gears to rebuild but I don't know if it will be worth the time. I'm running the 2-spd now which I'm having that issue with. I'll post some pics of my Sav later.
#5833
Nice shock covers. Where'd you get them? Also, how do you embed the pics in the message area. I'm fairly new to this forum stuff. It's not allowing me to paste my pics in.
#5836
hey brio thanks im running the 3 speed with the high speed 3rd gear and bp diffs, killed the gearbox recently, the front bearing collapsed on the output shaft which wrecked all the gears except 2 and the front casing of the gearbox, i just put the 3 speed back in cause i love hearing it change gear, but thats not bad cause its got about 9-10 gallons on it now with the lrp
#5837
well I finally got of my lazy ass and took a pic of my Savage .25 to BL conversion
So far only disappointment I have with it is the castle system I decided to use that hates my radios and will not let me calibrate it. I'm currently thinking about getting a HW BL ESC and using that. Other than the castles ESC sucking the thing runs great.
And if anyone is wondering the battery trays are cut down stampede chassis's I dyed black and bolted to the side with a piece of lexan to protect and hold in the battery. they work great
#5838
@ wolfie1.... I'm glad to hear that the LRP is lasting so long. I like those phatlinetires also.I cleaned out all the shreds of plastic out of my 2-spd. gear box from a stripped 39T gear and it seems to be running OK. I was stripping gears on the regular before. What kind of glow plug you running in the LRP? I've been using MCcoyhot and alsomed. and they seem to cause ultrarich conditions after a few runs. I'll be posting some more of my Savage pics.
#5839
My Feedback: (18)
all my toys. custom paited,one flux the rest are nitro.the purple cuda is a 4.6 ported and polished with alot of goodies.my fastest one,besides the flux witch will do 60mph no problem.as long as it dont catch fire.it did that 3 times already
#5840
Thats a bold claim.. I will send you $20 to your paypal account if you make a vid with a radar confirmed 60mph on one of those trucks (not the flux).... None of those are going over 45-50mph (being very generous with the numbers) with those wheel and tire combos, I'll tell you that.
#5842
ORIGINAL: rcnitrohead
He didn't say anything about the speed of the nitros other than his flux was faster
#5846
brio i am running mccoy mc9 plugs in my lrp i was running hpi r4 at first but mccoy are £2 cheaper a plug and also thats the ones been recomended, i have been thinking about how many gallons are on my lrp and its 10 at an absolute max, just now i have a nosram rs30 cooling head on cause i broke 2 fins of the lrp head exact same except that its red
#5848
holy crap! thats in there alright, i worry about taking my models in stuff like that in case i destroy something, thats well cool tho
#5849
My Feedback: (18)
you can just take your servos and were the seam is on the servos put high temp gasket sealer around the seams,let dry overnight.then they are waterproof
