3speed wont shift
CO
3speed wont shift
hey hey hey i just installed a 3speed on my savage and umm well it doesnt shift into second or 3rd. i have an sts.28 with 15/52 gearing. I didnt touch the settings so help appreciated.
RE: 3speed wont shift
You also have to be sure the thingamabob and the thingamajig are correctly aligned with the thingy before you tighten down the whoseywhatsit.
i think you will find that it does shift, it just does it as soon as u put on the power, its set up for a 25. Try going about 3/4 throttle so it aint flat out and see if it shifts (25 power) and then if it does, just lengthen your shift points.
