Upgrades for savage
MN
RE: Upgrades for savage
Well a tuned pipe and motor saver air filter are about your only options. Are you looking for more top end or more acceleration, or both? You can use different gears to make either acceleration or top end better but changing one will have the opposite effect on the other. The only way to see a big increase in top end and acceleration is to replace the engine.
slam it to the ground ,get some proline crime fighter tires with dish wheels ,port and polish the engine, dremel every single piece on the truck, everything thats aluminum make titanium, get a three speed, and a jp-2 pipe and motor saver air filter
The LE already has a tuned pipe, and a decent air filter, so as mentioned above you could port and polish the engine.
But unless you're confident in attempting this? i'd leave it be, coz otherwise you'll do more harm than good.
Porting and polishing your engine will make a noticable difference though
