cracked fuel tank
cracked fuel tank
whats the best way to fix a hair line crack in my fuel tank....i tried the good old JB weld and the nitro just ate it away. will CA work or do you think it too will be eaten away?
RE: cracked fuel tank
Ca glues wont help you. A friend used some special aircraft adhesive which worked on our tanks but it is super expensive, we only used it cause he got the stuff for free. Buy a new tank.
NM
Buy a new tank & zip tie it to the side plate to keep it from banging against it & cracking on the inside side. That will solve half of the problem. A tank gaurd helps but its plastic man & that truck is hauling *****.
