speed gear stock values needed
WI
Hi,
I have just finished break-in of my 25 but 2 speed set up is probably wrong. I get into second gear tooo late. What is the factory default for 2 speed set up, especially how many counterclockwise turns after we all turn it to clockwise? As i remember from the forums it has to be 3.5 bu i am not sure.....
Need help THanks!!!!
RE: speed gear stock values needed
ORIGINAL: rcwrx
Hi,
Hi,
Between 3 and 3.75 turns should be close. Every truck shifts a bit different. If your truck is shifting too late, adjust the shift setscrew counter clockwise 1/4 turn and try driving again, until you get the desired shift time
