heres my winter mod.
AK
heres some pics of my winter mod and my homemade tie rod end. thats a paint cap over the air filter. and then the head has tin foil wrapped around then black electrical tape and then a plastic cap with the lid cut out and its taped on also. even with all this it still doesnt hardly get up to temp easily. i also use os hot plugs.
RE: heres my winter mod.
thats pretty cool. But having tin foil wraped and taped around the cooleing head doesnt effect the way it runs??? I wouldnt want to do that because those fins help get air, and with all that stuff on it, it cant get air. Also, why did you put the foil and then black tape on it anyways??
cchrider
cchrider
AK
black tape holds it all together. its all part of the gRAND SCHEME OF THINGS. the head doesnt need any air if your not trying to keep it cool.
ORIGINAL: the dog
Well you are thinking in the right direction, BUT wrapping electrical tape around your cooling head is a BAD idea. With a properly tuned engine, your cooling head will see temps around 250F which will quickly MELT that tape into a ball of burned plastic. If your engine is not getting up to temp you need to lean it down a bit. As for your cardboard over your filter, that's not necessary either, and you are seriously choking off airflow to the carb. I run 2 Savages all winter long, with just some thin sheetmatal zip tied to the head to block SOME, not all airflow. As for your air filter, run a Motorsaver with the thick dust sleeve, and you won't have any problems. MAKE SURE YOU ALWAYS RUN A BODY IN THE SNOW AND ICE. This keeps out most of the snow when bashing. I have a "winter only" body that has no extra holes in it.
NJ
ORIGINAL: Polar_Bus
Well you are thinking in the right direction, BUT wrapping electrical tape around your cooling head is a BAD idea. With a properly tuned engine, your cooling head will see temps around 250F which will quickly MELT that tape into a ball of burned plastic. If your engine is not getting up to temp you need to lean it down a bit. As for your cardboard over your filter, that's not necessary either, and you are seriously choking off airflow to the carb. I run ,y Savages all winter long, with just some thin sheetmatal zip tied to the head to block SOME, not all airflow. As for your air filter, run a Motorsaver with the thick dust sleeve, and you won't have any problems. MAKE SURE YOU ALWAYS RUN A BODY IN THE SHOW AND ICE. This keeps out most of the snow when bashing. I have a "winter only" body that has no extra holes in it.
ORIGINAL: the dog
Great Advice
AK
thats not cardboard, its a plastic cap. and theres a decent gap all the way around the air filter.. and the tape is on the outside of alluminum and it does get hot but seems to stay on. i do have to also put a glove over head when i first start then it get hot and ill take it off. i have to be careful thouh cause a couple times upside down in the snow and the head gets ice cold fast.
i think it was polarbus that told me about all this and you were right about it all. runs light years better hot rather than cool.
NJ
ORIGINAL: rjfabrication
What exactly is this winter that you speak of???
AK
ha,ha. (sarcasm)
i know this place does suck big time. way to freakin cold.
im going on vacation on the 3rd so ill thaw out a little.
we are moving south next fall. still in alaska though.
ca is good temp state.
