Savage 4.6 compression
Hello
I just wanted to find out how to tell if the compression on the 4.6 is ok, when i pull the pull starter the engine is very loose, it has just run about 2 gallons of fuel throught it.The engine still has lots of power so i am not sure if it is on the way out.
RE: Savage 4.6 compression
I can spin the flywheel, its loose but takes some effort to turn.
Still leaning towards the os 30vg, anyone had experience with the engines?
