HPI 1/8 Savage SS 4.6 Kit
ok im not new to the hobby but new to this truck i have $700.00 to spend plz let me know if there is any thing else i need or could sub out for off of my list..
Accessories Needed Combo Available
1 403.99
LXCY32 Pactra Polycarb 3 oz. Metallic Black
A 1 5.29
LXKAD7 HPI 3-Speed Savage Transmission Upgrade Kit
1 49.99
LXFYM4 HPI Glow Plug Cold R5
2 5.79
LXFKM1 HPI Spur Gear 49T Savage SS
2 3.89
LXHCF1 Ofna NiMh Battery Charger 110VAC
1 7.59
LXFJT1 HPI 5-Cell 6V 1200mAh Hump Receiver Pack
1 21.99
LXCY22 Pactra Polycarb 3 oz. Metallic Blue
A 1 5.29
LXANT4 Hobbico CS-70MG Servo Super Torque 2BB U
1 34.99
LXUK84 Tower Hobbies TS-53 Servo S3K Standard U
Combo Available Qty Discount Available
1 9.99
LXGAG2A5 3PM FM R133F NO SERVO A5
Accessories Needed
1 119.99
LXK286 Great Planes Pro CA+ Glue 1 oz. Medium
Accessories Needed
1 3.99
LXJ481 GloBee GloCharger Glow Plug NiCd Charger
1 14.99
011RH SAVE $60 ON $599.90 order
Applied during checkout process if this order qualifies
Sub-Totals: In-Stock Items: $697.45
thanks ryan
1 403.99
A 1 5.29
1 49.99
2 5.79
2 3.89
1 7.59
1 21.99
A 1 5.29
1 34.99
1 9.99
Accessories Needed
1 119.99
Accessories Needed
1 3.99
1 14.99
thanks ryan
QC, CANADA
RE: HPI 1/8 Savage SS 4.6 Kit
umm...
Im not sure what some of those items are because i dont know items by their model # if thats what you put down.But if your changing your steering servo then use the old one to put in for brake/throttle.Save a few bucks there...
NY
I'd add a few things to that list. Here are some parts, all availabale from Tower Hobbies.
Exhaust Deflector – Attach to stinger, to keep the pipe from spitting fuel all over your rear wheels
http://www2.towerhobbies.com/cgi-bin...3&I=LXD636&P=K
Dubro In-Line Fuel Filter Purple - The Savage doesn't come with a fuel filter
http://www2.towerhobbies.com/cgi-bin...3&I=LXFRL9&P=K
Futaba SWH13 Switch Harness & Charge Cord Mini J - Drill a hole in the radio box, and hang the charge jack out through the drilled hole.
This will make it MUCH easier to charge your hump pack.
http://www2.towerhobbies.com/cgi-bin...3&I=LXH462&P=K
Ofna Flywheel Wrench - This will make flywheel installation much easier
http://www2.towerhobbies.com/cgi-bin...?&I=LXBDV1&P=7
Mugen Aluminum Clutch Shoes MBX-5 (3)
http://www2.towerhobbies.com/cgi-bin...?&I=LXJAP0&P=7
Mugen Clutch Spring 1mm MBX-5
http://www2.towerhobbies.com/cgi-bin...?&I=LXNJ81&P=7
Mugen Engine Nut (SG) MBX-5
http://www2.towerhobbies.com/cgi-bin...?&I=LXNJ78&P=7
Swap out the stock clutch shoes, springs and pilot nut for the Mugens. The stock clutch is just too weak for the 4.6 engine, and will cause problems from the start.
I'd do all of these before I bothered with the 3 speed tranny.
I assume that you already have after run oil, a fuel bottle, fuel and temp gun.
Also, don't fit the 3-speed until the car is well run in..... Because the car will loosen up a lot after a gallon or so of fuel, and all the changing up points will be different.
sweet thanks for the input i will hold off on the 3 speed and i added the clutch to replace the stock one thanks
And yes i have all the suport eqp....
Manufacturer and Product Description ITEM NOTE Order Qty Ship Qty Back Order Qty Price Each Remove From Cart
LXJUP1 HPI 1/8 Savage SS 4.6 Kit
1 403.99
A 1 5.29
1 5.79
1 3.89
1 7.59
1 21.99
1 34.99
1 9.99
Accessories Needed
1 119.99
Accessories Needed
1 3.99
1 14.99
LXNJ78 Mugen Engine Nut (SG) MBX-5
1 7.19
LXNJ81 Mugen Clutch Spring 1mm MBX-5
1 4.29
LXJAP0 Mugen Aluminum Clutch Shoes MBX-5 (3)
1 20.59
LXFRL9 Dubro In-Line Fuel Filter Purple
1 3.99
LXEMG5 DuraTrax FlashPoint Infrared Temperature Gauge
1 22.99
LXD531 DuraTrax Kwik-Pit 250cc Fuel Bottle
list updated thanks guys
any one else??
1 403.99
A 1 5.29
1 5.79
1 3.89
1 7.59
1 21.99
1 34.99
1 9.99
Accessories Needed
1 119.99
Accessories Needed
1 3.99
1 14.99
1 7.19
1 4.29
1 20.59
1 3.99
1 22.99
any one else??
