exhaust position
exhaust position
Is there a conversion to make the exhaust placed at the rear of the car? Its just that every time i use it, un burnt fuel sprays against the chassis and basically the whole right side of the car. It gets really annoying, i'd rather have it spray against the shell like my other cars do.
RE: exhaust position
cool, may be worth a try. Although the exhaust doesnt look all that good quality wise. Dont you think its annoying how it sprays all over the car though?
it would be easier if you could just turn the pipe and drill a hole through the body so it spreays against the shell, havnt looked at it so i dont know if its even possible but it might be.
ORIGINAL: kurtf5
how does that work?
how does that work?
Banned
I had a slimline dual exhaust for my t-maxx, and I hated it. The way it mounted sucked, and no matter how much pressure you used to zip-tie the exhaust coupler, it would leak and be all over the back of the truck. It is cheap, and that is about the best I have to say about it. It maybe totally different for a savage, but I will not buy slime line ever again. I would look/get the TSAV01 c5H "Category 5 Hurricane" DUAL REAR-EXHAUST PIPE SET FOR THE HPI SAVAGE. This pipe is made by Tsais. It mounts nicely to the truck, and is one great pipe. The price is on the high side ($79.99). The pipe is a fully functional 3 chamber pipe which increases mid-range and top-end performance. The slimline is only a one chamber pop can.
http://tsais.com/products/exhaust/tu.../prototype.wmv
CO
ORIGINAL: kurtf5
yes i will, i only wanted it to stop spraying fuel so ill just get a deflector for £2.
Thanks. The rear exhaust looks cool though, could get damaged pretty easy though.
A friend of mine had the exhaust deflector and it altered the sound of the engine, so I'm not sure if it affects performance. I angled my exhaust away from the chassis by drilling a hole at an angle in the plastic exhaust mount and it worked perfectly.
BC, CANADA
im sure it does! it increses the preasure in the pipe! even wider diameter deflector affects the performance, its not bad though, jus re-tune the engine.
MN
all its doing is extending the exhaust tip down there is noway it could effect the performance by adding back pressure ... there is no baffle ... no restriction ... bigger diameter ... not like it fits inside the tip then it would ... i put one on my savy and no performace change and no sound change
I have tried the pipe deflector and still use it. No matter how you angle it, you will still have build up somewhere under your chassis. I angle mine under the truck but still have crud by rear diff.
I DON'T THINK I WOULD TRY JayC1968's METHOD...THAT MUST ROB SOOO MUCH POWER!
Actually ill be pleased to say, if you angle the deflector so its bent FACING the front wheels, the air resistance forces the fuel to flow onto the floor, it doesnt spray AT ALL against the car! man it works great.
