HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
diff problem help
Old 06-07-2006 | 11:52 AM
Banned
Default diff problem help
i was running my savage the other day after rebuilding every thing except for the ring gear on the rear diff i sall that it was worn down and plus there was alot of play but i put it in anyway but when i ran it every time i would get on thew throttle it the rear diff would make 5-6 clicking sounds should i replace the ring gear[sm=confused.gif]
any help would be appreciated
Old 06-07-2006 | 11:56 AM
slodsm's Avatar
Default RE: diff problem help
Yep, most likely it's you pinion skipping on your ring gear due to being worn. If you rebuild it and shim it well though, you should get a lot of life out of it man.
Old 06-07-2006 | 11:58 AM
Banned
well its a 3 1/2 year old pinion and ring gear
Old 06-07-2006 | 12:04 PM
slodsm's Avatar
Then you got your moneys worth out of that one [&:]
Old 06-07-2006 | 12:08 PM
Banned
yea really ok so i should change that and then see wat happens?
Old 06-07-2006 | 12:12 PM
slodsm's Avatar
Yep, it will take care of the problem. I don't know if you have ever noticed but when motorcycles take off hard, sometimes they make a similar sound. It's the same thing happening because the front teeth on the sprocket are worn down and the chain is skipping.
Ring and Pinions can do the same things when they wear.
Old 06-07-2006 | 12:20 PM
Banned
ok thanks alot now i dont have to spend all day on the truck trying to guess wat part to pick up from the hobby shop
Old 06-07-2006 | 05:34 PM
badboy2's Avatar
My Feedback: (13)
im also having probelms but not sure if its the diffs..the front wheels wont turn like the brakes is engaged..i tried turning them with hands and its hard to turn them is this a diffs problem or something else.imagine the wheels lifted and try to turn them and they wont turn..i have to force the turn with my hands and only 1 wheel is turning..
Old 06-07-2006 | 07:54 PM
theddy's Avatar
i was very happy yesterday to know that i have someone to compete with my stock savage x. the guy next to my apartment got a tmaxx and we dragg raced yesterday. i was very happy i was 2 feet ahead all the way. but it was a short time because his tmaxx broke. i'm glad i have a savage x. but today i cleaned and lubed my savy and test drive it so i could have a good tune once he fixed his tmaxx. but to my surprise after having a couple of good jumps and wellies. it was only the front wheel that is running (turning). why is that? is it my diff? haven't opened it yet. i have 3 gallons on it already is it the average lifespan of the savage x diff?
Old 06-08-2006 | 11:46 AM
Banned
ORIGINAL: badboy2
yea its ur diffs cause mine do that and its my diffs take it apart and look at the pinion and ring gear it should/might be 1 of those
Old 06-08-2006 | 09:09 PM
burkes_22's Avatar
i rebuilt my front diff yesterday with an alum diff cup and it is very tight when i try and turn it, it is like it is binding, like when you have your spur set wrong, how can i fix this? i've heard people talking bout shimming diffs but never tried it is this the problem?
