HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
STS Engines
Old 04-04-2007, 08:07 PM
  #251
jombo
jombo's Avatar
Default RE: STS Engines
ORIGINAL: TopSpeedToys
ORIGINAL: jombo
i pulled mine out to check them and a silver and one copper is .04mm, i dont see how it could possibly be .03mm. i dont have digital calipers just the ones with the lines on them so that may make a difference.
Jombo, you're off by a couple of hairs
in the engine you should have 3 shims, a .1, .2 & .3mm (not .04mm as you stated).
The manual says run .5mm for 30% nitro.
So... you need to combine the .3 + .2 shims to total .5mm
No need for a caliper, it is obvious that one shim is thin and other really thick... the .2mm will be the middle one
Understand?
-Mark
i dont think you opend one up recently, here are three shimms ans i have a silver and a copper in the engine now. the closest i got with the calipers i have is .4mm. it dosent matter as long as its close i am only breaking it in with 20% and staying with it.
its all good
Old 04-04-2007, 08:17 PM
  #252
benzzyo5
benzzyo5's Avatar
after you brrreakin the egine and all, how many shimms should you have when your using 20%? one copper?
Old 04-04-2007, 08:20 PM
  #253
46u
46u's Avatar
ORIGINAL: BCKoots
ORIGINAL: 46u
The only thing I would do different from the instructions is use 20% to break it in and do not shim it till after at least a gallon.
Don't shim it untill after a gallon!??, I must be way confused, I thought you dont REMOVE the shims until after a gallon?
Sorry if I phrased it wrong but yes do not remove or change the shims till you have at least a gallon of run time on it.
  #254
jombo
jombo's Avatar
thats just it, i copper is like .1mm and 2coppers are .2mm. with the shims i have or that came with the engine are more than .5mm. but the closest i got is a copper and a silver which is a little over .3mm.
Old 04-04-2007, 08:24 PM
  #255
46u
46u's Avatar
ORIGINAL: benzzyo5
One 3mm for 20%
Old 04-04-2007, 08:27 PM
  #256
benzzyo5
benzzyo5's Avatar
thanks!! so run one copper and one silver?
Old 04-04-2007, 08:28 PM
  #257
jombo
jombo's Avatar
ORIGINAL: 46u
ORIGINAL: BCKoots
ORIGINAL: 46u
sorry 46u i'm going to be different, i am going to run it with the 2 shims for 20% and see if that makes a difference in breakin. in the directions it dosent say not to for breakin, it only gives recommended head shiming for the nitro you are using.
Old 04-04-2007, 08:29 PM
  #258
jombo
jombo's Avatar
yes for 20% only a silver and a copper. but measure them to be sure.
  #259
benzzyo5
benzzyo5's Avatar
^^ if you have the V2 engine series then you have to break in the engine for at leased one gallon before moving any....you do because this engine is so tight that you need the shims to reduce the compession
Old 04-04-2007, 08:31 PM
  #260
benzzyo5
benzzyo5's Avatar
ORIGINAL: jombo
i don't have a thing to measure it.
Old 04-04-2007, 08:35 PM
  #261
jombo
jombo's Avatar
i dont think you have that right or i may be wrong , i thought since your running a lower nitro content you use less fuel to ignite less compression, higher content (more compression) more fuel. isint that with full size cars higher octane more compression less compression lower octain.
Old 04-04-2007, 08:41 PM
  #262
46u
46u's Avatar
I do not have a 30 or any 30 head shims but I just open a new pack of 28 shims and this is what they measure. One copper is .1mm, one is .2mm and the silver one is 3mm. Like I said when I got both my D21B engines they only had to shims.
So for 20% you only run the silver shim. But you cold run the .1 as wll to be on the safe side.
Old 04-04-2007, 08:43 PM
  #263
benzzyo5
benzzyo5's Avatar
i think i read that supertib was running one silver shim with 30%. but the .30 shims might be different.
i apriciate the help though...thanks
Old 04-04-2007, 08:52 PM
  #264
46u
46u's Avatar
If you look at the explode view it shows all engine have one of each so I do not think there will be any difference. If you go to the link I posted above you will see. It plainly says as the instructions for ALL their big blocks are the same.
Up to 20% .3mm Will it really says under but I feel this is up to!
25% .4mm + or - .1mm
30% .5mm + or - .1mm
Now it is your engine so people many do as they like but do not talk bad about the engine if you have problems and do not fallow the advice of those that have been working with these engines for a while. The pinch is so tight and the compression is so great more shims during break in puts less stress on the engine.
Here is the link again.
http://www.stsmicroengines.com/docs/d30m-manual.pdf
Old 04-04-2007, 09:15 PM
  #265
benzzyo5
benzzyo5's Avatar
thanks, and yeah i know the sts's are great i had one and i loved it. thats whay i want another one.......lol\
thanks
Old 04-04-2007, 09:29 PM
  #266
ThunderbirdJunkie
ThunderbirdJunkie's Avatar
off topic, but...
46u, I learned a little trick from my dad.
Never keep digital or dial calipers in your toolbox. if you have vernier calipers, nobody else knows how to read em so they don't borrow em
Old 04-04-2007, 09:35 PM
  #267
46u
46u's Avatar
ORIGINAL: ThunderbirdJunkie
off topic, but...
So true as I have had people ask to borrow mine I hand them to them and they hand them right back. All so vernier calipers can take more of a beating with out getting messed up.
Old 04-05-2007, 01:15 AM
  #268
Grover6
Hey all! I recently ordered an sts .30 with tuned pipe. Hopefully it will be here in the next couple of weeks. I would like to know if there is a clutch that anyone would reccommend to rplace the original. I will be putting it in a Savage X. Also if anyone who has run one of these engines can give me any tips and tricks for setting it up. Thanks.
Old 04-05-2007, 02:06 AM
  #269
HeatFire
HeatFire's Avatar
ORIGINAL: BCKoots
Forgive me if someone asked this before. Will it be neccessary to seal a brand new STS 30?
Yes yes, allways seal your engine.. saves you alot of time if it leaks to already have it sealed since you dont have to clean it out either
edit: maaan, alot off time waiting for USPS to show my package on their tracking system.. want my engine nooooow... god bless USPS
Old 04-05-2007, 08:43 AM
  #270
BCKoots
ORIGINAL: HeatFire
Great, thnks for your help. USPS not showing my tracking info on there system either. Cant wait for my engine to get here!
Old 04-05-2007, 09:01 AM
  #271
HeatFire
HeatFire's Avatar
BCKoots atleast you have an Axial 32 engine.. i'm stuck with my F4.1 for now.. sluggish engine..
4-6 days for it to come here? pffft 4-6 weeks if they dont get it mooooving soon
lets see who gets their engine first
vernier calipers?? easy to read.. never use anything else.. dont trust those digital once.. rather just use the good old vernier calipers :P
anyway.. internet got more guides about vernier calipers then needed.. so if you forget you can allways relearn..
anyone knows how many gallons the bearings can handle.. and sleeve and.. piston?
Old 04-05-2007, 09:44 AM
  #272
46u
46u's Avatar
ORIGINAL: HeatFire
ORIGINAL: BCKoots
I agree as I all ways seal my engines when new to be on the safe side.
Old 04-05-2007, 04:16 PM
  #273
yfz450_rida
when is stsmicroengines expecting to get any dm30's and tuned pipes in? i am in the checkout process before i realized they are out of stock. any ideas?
Old 04-05-2007, 04:34 PM
  #274
TopSpeedToys
TopSpeedToys's Avatar
ORIGINAL: yfz450_rida
YFZ... Motors are in stock, the pipes are due next Wednesday 3/11.
-Mark
P.S. yfz450_rida... are you Kyle? If so, you are ok and bought that last pipe.
Old 04-05-2007, 05:21 PM
  #275
yfz450_rida
haha awesome! ya thats me. sweet deal.
