diffs on savage
MI
diffs on savage
I was wondering if anyone has devised a way to take care of the problems with savage front diffs going out periodicly. It seems like theres some slop in the gear mesh and the first time the front end is put under stress, they wear down quick. My freind has the same issue with his savage and he suggested maybe putting in some shims or spacers on the pinion gear to add more pressure against the ring gear. Just wonderin' what you guys think or if you have better ideas. Thanks
LA
RE: diffs on savage
You need to shim the diffs. Here is how to do it: http://www.beatyourtruck.com/forum/s...ad.php?t=14020
RE: diffs on savage
That is pretty good, but he is only shimming half the diff. you still can run into problems. This should help if you need to know what to order or have any ??? let me know...
ON, CANADA
RE: diffs on savage
ORIGINAL: Rexzilla
Get the Cen diffs and be done with it they are bullet proof
is it that easy?
do you notice any difference in the gearing.
RE: diffs on savage
ORIGINAL: mazdab2600
i've been reading up on it.
is it that easy?
is it that easy?
As for the gearing, we were a bit worried as they are a bit taller than standard, but it is fine, I have a 3 speed and 48/16 RRP spur and clutch combo, with the old 4.6 it was great, with the STS D30M it will pull wheelies and power stand into second gear
