Does anybody make 17mm hub adapters...
VT
RE: Does anybody make 17mm hub adapters...
i think you gotta get the nubs conversion kit
http://www3.towerhobbies.com/cgi-bin...&I=LXLMD8&P=SM
nope poke around thier you'll find all you'll need to do the converstion with out ending up with new tires and
the lug
the lug
IL
Thanks Lug,dang i still cant find anything.Ive got black Maximizers on the way,and i cant have any damn purple on my truck.Last time i checked this was a male dominated hobby,why in Christ's name is purple even an option?Say,does anybody know the "de-anodizing"process,at the least ill buy purple and find a way to get that crap off there.
VT
i knew some one had a post about that a few weeks ago i'll try to find it
yup here it be
http://www.rcuniverse.com/forum/m_75...tm.htm#7552271
the lug
yup here it be
the lug
VT
[sm=48_48.gif][sm=48_48.gif]not at all i'm board outa my skull playin' pebble dash so i figured 1 min of searching can't hurt
http://www.miniclip.com/games/pebble-dash/en/
for all you board people after you aim wait a bit....
the lug
the lug
OH
I have no idea who might make such a thing
*giggle*
Parts list:
8mm buggy-style axle for Savage 17mm buggy-style hub conversion kit (cannot use normal 1/8 buggy axles...I tried...and wasted $20[:@])
86393 x 2
http://www3.towerhobbies.com/cgi-bin...6393&search=Go
3mm dia pin for Hellfire axles to hold the hex on the axle
Z272 x 1
http://www3.towerhobbies.com/cgi-bin...z272&search=Go
M5 grub screws
Z741
http://www3.towerhobbies.com/cgi-bin...?&I=LXFKN0&P=7
3mm drill bit to drill out the 2.5mm hole that's already in the 17mm hubs, because if you don't there's gonna be an UN GODLY amount of slop
Can't find one at Tower, or on Harbor Freight's website, but i found a metric drill set that I used while perusing Harbor Freight. was like $8
and, last but not least...1/8 buggy 17mm hubs of your choice I used what was on the LHS's shelf at the time...no idea who made them, and don't care either
You can also buy those parts, and substitute the 17mm hubs for LST2/Mammoth ST 23mm adaptors (IN THEORY, I have not tried this...YET)
I went through THAT much trouble to get these parts to avoid the purple hubs. Oh well
*giggle*
Parts list:
86393 x 2
Z272 x 1
M5 grub screws
Z741
IL
ORIGINAL: robo5
What color are you looking for? i have colorless and gold
VT
purple can be cool but it takes the right trim schem and hpi don't got it, it needs to be a much darker purple if at all, they need like black crome or something
the lug
the lug
IL
ORIGINAL: ThunderbirdJunkie
*giggle*
Parts list:
86393 x 2
Z272 x 1
M5 grub screws
Z741
*giggle*
Parts list:
86393 x 2
Z272 x 1
M5 grub screws
Z741
OH
Integy has some 23mm adaptors, and pre-mounted 23mm wheels/tires that can be had for fairly cheap. I'm thinking about grabbing a set when I destroy this new set of rubber. Or maybe before, who knows...but the 23mm adaptors have to be for the Hellfire/LST2/Mammoth ST.
the CEN truggy may work, too, since it has them stock, it may be cheaper...but I'd have to know beforehand whether it took a 2.5mm or 3mm pin, since the pins for the 17mm hubs won't work as well.
