X dogbones with XL cups?
Is it possible to use the X SS dog bones with the XL cups? Seeing as they are 2mm thinner it shouldn't matter right? They are the same length. I bought the extended cups without realising they were for the beefier dogbones!
RI
RE: X dogbones with XL cups?
Not only is the shaft thinner on the x dogbones I'm sure the ball ends are too. So u will have a lot of slack and play. U run the chance of itpoping out or doing doamgae to the cups etc
And they wont be spinning true so you will get all kinds of vibrations, and run the risk of easly bending them due to the fact that they wont be spinning ture.
KS
ORIGINAL: spoonrc
Actually I just got my XL cups. Theres no play.. they fit fine and seem like I wont have any problems.
Why doesn't it work? They seem to slip together perfectly. The bone doesnt sit out, I realise that but they should hold up for a little while. Its not perfect but it will definitely will work. The only play is that the ball is 2mm smaller, once some o-rings/fuel line is behind the balls they should be ok.
I will just run them until they give way.
KS
The size difference is enough that the drive pins are not long enough to stay engaged. In the previous post the pins are not long enough to stay in the slot, they will slide out.
KS
I just checked the standard X bone in the Flux differential, same as an XL and you might get that end to stay in the drive cup. The X dogbones are very sloppy in the Flux cup, but they might stay. They will not stay at the other (axle) end. I have the parts free here and can shoot you a short video clip of a proper fit and the X fit, if you like. Remember that these will be turning an insane rpm and have no guide bearings for alignment.
Edit... I was just messing with them and the X bone will move far enough away from center for the drive pins to strike the differential bulkhead. I do not think you really want to run them that way. Glen
KS
The Differential Cups will work in either differential. Some of the XL advertisements claim a stronger pinion, but the old pinions are direct replacements and I cannot tell the XL pinion lasts any longer than the X pinions. The drive cups are larger and will fit the X differential. The dogbones are obviously larger and the outer axles have the larger cup. I have bent some XL bones by crashing, but have never broken one. If you want to run the heavy bones and not the added width, buy Flux axles. Glen
I just bought the x upgrade kit. I think I got the diff drive cups, standard width outer drive cups and hd axles for all four corners for 50 bucks or so from Hopmeup on ebay.
josh
josh
KS
When you decide to do wide, it will cost another 20-25 dollars or so. I like the heavier bones, even though they should take away a little power due to rotating mass. It is nice to to worry about breaking them. Glen
Thanks Budbud, big help! I will give them a try. LHS in australia really suck and over charge on everything so I always buy from the states and wait a week or so for postage. Just want to run this weekend. I am not using XL outdrives though I am using the XL wider cups.
TX
For those looking for a big meaty bone but don't want to convert to XL, FLM makes some really sweet ones. Been using them about a year and have never replaced one.
IL
about those X bones in the XL, I lost 1 in the Xl and my LHS didnt have the Xl bones and my buddy had a X bone laying around so I tryed it...The Picco twisted the ball 1/2 turn in no time..
Yep. Budbud is definitely right (as usual). The ball looks like it will pop out easily when turning and running. I am running a picco aswell and I can see that happening for sure. Going to play it safe and wait for stock of the XL cups and bones.
Okay, dont want to beat a dead horse but, Im looking to go wider for rollover issues. With the XL axles I will need to go with the diff cups and the axles also from the XL? I hate how the thing flops over at almost every turn. Or am I missing something? Oh yeah, its a Savage with the 25 in it. So a fairly older one. I got the axles off fleabay already but dont want headaches. Thankyou much for any/all info ya'll can provide.
Forgot dogbones axles and cups.
You might want to try softer shock oil as well or first. I found with my X ss it wanted to roll over easily too. That was with the stock set up. My XL has a soft set up though and I love it.
KS
ORIGINAL: wileecoyote
VT
ORIGINAL: KID_EVIL!
the lug
A 5.9 XL or flux ring and pinion are hardened, and machine cut.
they are black in appearance on the teeth.
The old savage 25 or the savage SS or I think the 4.6 regular X used a cheap stamped pot metal ring, and pinion, that are not as hard or tough.
