Blew a tranny.... wth lol
I'm getting a bit frustrated with my truck... Last time I was out running in a parking lot with shoestringracer, we banged into each other a few times and I bent up a shock from cartwheeling and ate a spur from my engine plate screws vibrating out. So I fixed all of that fun stuff today, and took the truck out for a test run..
Not even a full tank later, the tranny starts shifting more heavy for a minute- then 2nd gear is gone.. Now I've seen a lot of reports of modded Piccos eating 3 speeds, but I have a stock Picco .28 running 19/48 with BP diffs, the stock 2 speed, was running street tires and this happens. Granted I was running the original transmission with 13 gallons on it, but still- what the hell lol, this should not be happening.
Its the little things that keep adding up, when I replaced the regular diffs with BP units, I had them installed and the bearings decided to take a dump. I've put over 7hrs of work from replacing the diffs/shocks/random things and haven't even run it for a full 3hrs before having it die again.
Just venting my angst towards my poor savage [:@]. Sigh.. lol
RE: Blew a tranny.... wth lol
when my gearbox blew in my xl recently it was the front bearing on the output shaft that went i suppose i have nobody to blame but myself for not servicing them often enough
KS
I am not sure I ever had a tranny make it past ten gallons, but I always kind of enjoyed opening them up to see the destruction. I know you do a lot of speed running and a lot of jumping. You should bronze that transmission, it was a good one! 8^) Glen
ORIGINAL: BudBud
Well it turns out it wasn't the tranny, I opened it up and its still perfect inside after 13 gallons... It turns out the spur got loose, grrr I should have checked that first- but it didn't show any signs of being loose except for worse shifting, it was still grabbing fine on the low end. Now in the latest outing, I managed to kill 2 steering servos in one day, what the hell is going on lol... Killed 2 spurs as well, eh somethings not right.
RCnitrohead....You may wanna check your servo saver spring. Maybe you have it compressed too much, which would cause any goodimpact to damage the steering servo.
Talk about blown trannies.I've stripped so many 39T plastic gears in the 2-spd trannies running my LRP .30 and Idon't know why. Cou;d not figure it out!So far I've been having good luck with my 3-Speed box after I replaced two metal gears in it.
ORIGINAL: chevymanmike1010
blown two speed=reason to get 3 speed. Well for me at least.
The spring is fine, I killed 2 MG995 ebay servos, the cheap $10 kind... It was just inconvenient that I had 2 go in one day, but I can't complain since they lasted 2yrs for $20... I ran a whole day with a Traxxas 2055 in there for steering and it was fine.
