Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software > Ikarus Aerofly flight simulators
 9CAP setup with Commander Version, USB Slave and Adapter Cable >
Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
Old 10-08-2005 | 10:13 AM
IShootSharpStix's Avatar
Default 9CAP setup with Commander Version, USB Slave and Adapter Cable
I have the AFPD Commander Version and have just picked up the USB Multi-Player Slave and Futaba Adapter Cable from Ikarus to enable me to use my 9CAP with AFPD. I have everything connected, the radio is powered on and set to a PPM model. Windows XP does recognize the device as "Ikarus Interface" and the status is OK. I am unable however, to use the Windows XP "Game Controller" interface to test or calibrate the device. It does not recognize any inputs from the 9C. Further, I can define the new controller in AFPD as USB Dummy Intf#0 and it shows as active, Status is OK and it detects 12 channels. I however, cannot calibrate through AFPD either as it also fails to recognize any 9C inputs.
I assume the radio must be powered on and is, and that the RF Module is also left in the Radio. Does anybody know the proper installation steps to get a 9CAP to work with the previously mentioned environment?
Old 10-08-2005 | 11:16 AM
Default RE: 9CAP setup with Commander Version, USB Slave and Adapter Cable
Have you downloaded the V1.8.0.21 Patch???
BW!
Greg.
Old 10-08-2005 | 12:28 PM
Yes, downlaoded and installed.
