Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
AFPD Screen Size problem
Old 11-13-2005 | 07:41 AM
Default AFPD Screen Size problem
I have AFPD but am getting extremely low FPS (below 5) but only when in a full screen setting of afpd (which I want to be in). If I select 'window mode' the fps is up 166+ and the sim flies brilliantly, and even continues to remain at a high fps rate when i enlarge the window to fit the screen........but this is not 'full screen'
Can you help? What do I need to download/ switch on etc..!?
I've updated my Nvidia drivers, but still with no success.
Anyone experienced the same? How do I resolve it?
Old 11-13-2005 | 10:19 AM
Default RE: AFPD Screen Size problem
I have resolved the major issue! Right click on the AFPD program Icon, and select the 256 colours box. FPS is well up now (over 150) but colour has to be set at 16 bit.
Old 11-13-2005 | 10:22 AM
exeter_acres's Avatar
which vid card??
programs running in the background
Old 11-13-2005 | 11:06 AM
Geforce 6200 TC.
I turned off all background programs to see if it would help. Only problem having 16 bit colour, is that the colours in the sim, aren't very good.
Old 05-18-2007 | 01:10 PM
Any solution to this problem? I'm still not getting then'full experience' due to having to run full screen in 16bit colour. Would prefer 32bit colour! Anyone know what up with my setup?
Old 05-18-2007 | 01:49 PM
Big feet's Avatar
What screen resolution are you set to? 1024x768 or 1280x1024 etc.
Old 05-18-2007 | 02:09 PM
1024x768
Old 05-18-2007 | 06:43 PM
rajul's Avatar
Moderator
My Feedback: (58)
Your video card specs might be on the lower side. Is your video card set at full acceleration?
Also you might want to check that under "options" in the main AFPD menu, you have chosen texture quality at "high" and ticked "texture compression". In the flying menu, under graphics, disable options like smoke, clouds, and verticle sync as these will take up more graphics card resources.
Old 06-01-2007 | 07:44 AM
I'm now running an Nvidia GeForce 7300GT which has sorted the screen size probs. Now got brilliant FPS and all's fine with that.
New problem has occured that above the aircraft when I'm flying, several black lines keep appearing.... I've tried the AFPD updates with no luck, I've also done the update to allow Starflight add on to work but still the lines appear.
Was going to try uninstalling and reinstalling the program but there's an error message which wont allow me to do so!
Anyone heard of this problem? got a fix? I'm just longing for this thing to work perfectly.
Cheers
Dave
Old 06-01-2007 | 09:28 AM
rajul's Avatar
Moderator
My Feedback: (58)
Dave, try downloading and installing the latest nvidia graphics driver for your card.
Old 06-01-2007 | 12:55 PM
I have the latest driver....No change.
[&o]
Old 06-01-2007 | 11:37 PM
rajul's Avatar
Moderator
My Feedback: (58)
Hi Dave, are these black lines about a few cm long and about one pixel width, appearing above the airplane? Do they appear in certain scenery backgrounds only, and do you observe them when the FPS become higher? What type of monitor are you using, and the refresh rate?
This problem could be caused by the relatively slower refresh rate of your monitor. Under "graphics" menu in AFPD, try enabling the vertical sync and see if this helps. This may bring your FPS down however.
Alternatively, see if you can increase the refresh rate of your monitor, and see what happens.
Old 06-02-2007 | 04:25 PM
Vertical sync on, goodbye little lines!
Mike, thanks a lot for your help and suggestions. Very much appreciated.
I can now enjoy Aerofly to the full.
Dave
Old 06-02-2007 | 10:28 PM
rajul's Avatar
Moderator
My Feedback: (58)
Dave, sounds good to me. For my own info, can you tell me what range of FPS are you getting now, and previously without vertical sync? Thx
Old 06-04-2007 | 05:42 AM
It's gone from 389 FPS to 75 FPS with vertical syn on.
What does vertical sync do?
Dave
Old 06-04-2007 | 05:46 AM
rajul's Avatar
Moderator
My Feedback: (58)
With vertical sync on, the frame rate and monitor refresh rate are in sync hence only 1 frame is displayed per refresh
