Disk Problem
CA
I had a problem with AFPD which I had once before. In the past I uninstalled the game and reinstalled it and everything worked fine for a year or so. This last time I tried to reinstall it, it would stop during the install and give the following message and then exit the install program:
D:\data2.cab
The archive is either unknown format or damaged
how do I get around this and reinstall the program?
Scott
D:\data2.cab
Scott
CA
Hi,
The version is: 1.8.0.9
The disk is a couple of years old but has always worked. I used a disk cleaner and no change. There looks to be some small irregularity in the disk, it is not on the surface though.
Scott
Scott
Moderator
My Feedback: (58)
Hi Scott, please ship your bad disk to the service department below for a replacement with a brief description of your problem, daytime phone number, and email address. You may attach this thread for reference.
Hobby-Lobby International
ATTN: Aerofly Returns (Freda Watson)
5614 Franklin Pike Circle
Brentwood, TN 37027
ph. 615-373-1444
Brentwood, TN 37027
ph. 615-373-1444
