Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
Need help with USB cable
Old 08-28-2009 | 04:55 PM
Default Need help with USB cable
I received a replacement USB cable. The old one went completely south. I now have two problems. First, I get the error message indicating that the transmitter cannot be found. The second error message I get is that Add-on 3 needs to be activated. When I try to activate online, I get notification that the code is already used. I have Aerofly Pro Deluxe v1.11.07.21. My PC is running Vista Ultimate. Iam using an old JRXF421ex transmitter without the TX module. I have used this Tx before with APD. Here is a pic of my USB cable. Any advice would be appreciated.
Old 08-28-2009 | 08:13 PM
rajul's Avatar
Moderator
My Feedback: (58)
Default RE: Need help with USB cable
Hello mp, let's address your issues one by one:
1) "Tx not found error" - For JR radios, you will need to get a JR adapter cable, AFP-02 or IK31036. The adapter cable need to be connected between your radio and the usb interface cable. Ensure that your radio is in PPM mode.
2) Addon 3 activation error - Your new AFPD interface cable has a unique serial number (displayed at the top right corner of the main AFPD menu). Each serial number can only be registered to one addon. Your addon 3 is still registered to your older usb interface cable. Please PM me the following: your full name, address, email, new usb interface serial number, and addon 3 disk key. I will get a new activation code for you.
Old 08-29-2009 | 10:52 PM
rajul's Avatar
Moderator
My Feedback: (58)
Walt, I received your PM. I will try to get you a new activation code soonest possible.
Old 08-31-2009 | 07:52 PM
Mike, got the new activation code and ordered the interface cable.
Thank you very much for your support of this community.
Walt
Old 08-31-2009 | 09:20 PM
rajul's Avatar
Moderator
My Feedback: (58)
Sounds good and you're welcome!
