not exactly imac
My Feedback: (84)
KY
well this seems to be the only fourn soley devoted to this type of aircraft
so i have a question for you who are more experienced than i
i have a giles 202 by greatplanes
in order for it to be balanced it would take 2 more ounces on the tail(61 sf)
but i can fly it the way it is
my problem is that any more than a breath of elevator and it snaps
what can i do to fix this so i can get started into aerobatics with this baby
one more
i also have a 60 size cap 21
it has a 60 inch wingspan and a foam core wing
but i don't know the cg
i'm guessing 33.333 % of the wing cord at the fuse am i right?
any info on these would be helpful
one more
To be honest with you, do you have too much Elevator throw? I have been flying this plane for two seasons and found I needed to reduce the elevator rate and use generous amounts of expo and it flys like a dream. I also have a very rear biased CG. How do you know the CG is too nose heavy?
RickP
RickP
My Feedback: (84)
KY
sorry if this sounds dumb but what is expo
and if i ballance it acording to the plans it takes 2 aditional ounces on the tail
(i already have 2 on it)
you may be right on the throw but all i can do is a big lazy loop
of like 200 feet withought it snapping
thanks for the help
thanks for the help
TX
Don't put any more weight on the tail!! That will increase your snapping problem. How is your rudder trim? Check it by flying straight up and see if it falls to the same side every time. Trim the rudder to make it fly straight up.
Expo is a computer radio thing. WHat kind of radio are you using?
CJ
CJ
TX
Your airtronics doesn't have expo. Your best bet is to do what Rick said and reduce your elevator throw until the plane just stalls (or snaps). Check your CG in the air by rolling inverted and see how much elevator push it takes to hold level. A lot of push means your nose heavy. Some is good. None is bad.......ad nose weight. Make sure your rudder trim is adjusted as I described above and have fun with it!
CJ
CJ
TX
Expo makes the controls "soft" near center. In other words, if you move the stick half travel, the airplane surface will only move one fourth of full travel. The second half of stick travel will then command the remaining 3/4 of surface travel. It is nice for a very sensitive aircraft like your CAP. It's essential for 3D set-ups, nice for sport, but not required for fun flying.
CJ
CJ
My Feedback: (84)
KY
well i'll try those sugestions tomorrow but while i'm at it do any of you know anything about balancing a plane that you don't know the cg on like my cap
My Feedback: (16)
GA
I have put over 120 flights on my plane before I sold it. I had my CG at 9 inches and it makes the plane land a lot slower. You also need to make sure that your elevator is balance through-out the travel.
