31% aeroworks Edge 540T - DA-50 or G62?
RE: 31% aeroworks Edge 540T - DA-50 or G62?
I have my 31% edge540t ready but I lost my instruction manuel. I need to know how to set the throws and balence point. G62 Could someone post that info?
thanks
Bill
thanks
Bill
My Feedback: (10)
[/quote]
Also, the DA, 3W, Brison, BME, and ZDZ 50cc engines have better power than a G-62... My Brison 3.2 (53cc) turns a 22X10 Mejzlik prop at 7260 RPM. The spec sheet for the G-62 claims 7200 for a 22X10 prop... The G-62 is also at least a pound heavier, but it is also about $100.00 cheaper... Compromises... Compromises...
[/quote]
My G-62 turns a Mejzlik 22 x 10 at 7700 last time I checked. Had it converted to ignition my RCIGN1. Weighs 5 lb. firewall ready with battery and switch. Hovered my 20 lb. Giant Stinger just fine with plenty left to pull out with. I don't think would want to go to 21 or 22 lbs though if I was planning on doing much hovering.
[/quote]
