Go Back  RCU Forums > RC Airplanes > IMAC
 Seagull Extra 300 >
Seagull Extra 300
IMAC Discuss IMAC style aerobatics in here
Seagull Extra 300
Old 08-27-2004 | 05:23 PM
Default Seagull Extra 300
Has anyone seen or had any experience with the Seagull Extra 300. I'm looking for a home for a Satio 1.00, and wondered if that plane would be good at IMAC. Pulled the engine off a UCD3D and replaced with a YS1.20 for doing some 3 stuff.
tks
Old 08-31-2004 | 10:02 PM
Default RE: Seagull Extra 300
I helped a youngster build his. We did a few mods, like removing the existing engine mount, filling the holes, then using a GP 1.20 size mount we installed an OS .91 inverted. Less cowl hacking that way. The 1.20 mount allowed us to move the engine forward as these planes are tail heavy. We still mounted the battery on a platform under the engine box and then it balanced fine; slightly nose heavy in fact.
The plane is fine for entry level IMAC (Basic class). It is probably the fastest snapping plane I've ever flown, so it will not be suitable for Sportsman unless you have dual rate on the rudder and can take most of it out for snaps.
Great value for money, in my opinion.
Craig.
