Go Back  RCU Forums > RC Airplanes > IMAC
 methanol and or nitro in gasoline engines >
IMAC Discuss IMAC style aerobatics in here
Old 08-29-2005 | 12:33 PM
Default methanol and or nitro in gasoline engines
has any one tried using a little methanol or nitro (or both) mixed with their standard gas mix?
Old 08-29-2005 | 02:15 PM
Default RE: methanol and or nitro in gasoline engines
Most gas burners can be run on methanol with some oil mixed in, IF and only if, you rejet the carb as it takes a tremendous amount of methanol to get the power out of the engine. The jets for gas are much smaller and will not pass enough methanol.
Old 08-29-2005 | 02:51 PM
I mean only a couple of percent of each (nitro and or methanol) with the gasoline.
Old 08-29-2005 | 05:19 PM
My Feedback: (16)
Make sure your carb seals can handle the alcohol without damage
