Need 2006 Basic
Hey guys,
I'm looking to get into some IMAC this year.. I plan to work on it but I just really want to get my feet wet and see what it's all about. I want to fly basic, of course, and a written out routine is alot easier for my spotters to read. The only one I can find is the one with all the symbols, and it would take longer to teach myself and my spotter longer to read it then it will to learn to fly it. Any one know where to print one off? I have all of 2005's sequences written out.
On another note, I posted here a while back about my plane. Well I finally have the engine, and It wound up being a 3W 106CS edition. How will the Extreme Aircraft 34% Extra 300L/3W 106CS combo fare in IMAC (if properly set-up)? The all up weight should be at or less than 26 lbs. I'm a 3D guy but what prop should I buy to put on for IMAC? I was think Mejzlik, maybe a 3 Blade for noise reduction? i will be running in-cowl mufflers so I need all the help in noise reduction I can get to get under some fields noise limits. I'll be flying a MenzS 28X10 other wise but have heard it wouldn't be the best choice for IMAC.
Thanks Guys.
Thanks Guys.
1. Roll
2. Pull-Pull or Humpty Bump With 1/2 roll one the down line
3. Reverse Half Cuban 8
4. Loop
5. Hammerhead
6. Reverse Sharks Tooth 1/2 roll on the up line
7. Figure 9
8. Half Cuban 8
9. Immelman
10. 1 1/2 Positive Spin
All of the basic maneuvers exit upright.
http://www.teamflyingcirkus.com/videos/Basicsm.wmv
The problem with not starting to learn the basic symbols is that later on you won't be able to read the more complex ones.
4. Loop
5. Hammerhead
7. Figure 9
8. Half Cuban 8
9. Immelman
My Feedback: (32)
ICE,
Go here and read Dean's 11 topics. Great reading for IMAC
http://www.rcuniverse.com/forum/forumid_426/tt.htm
Then go here and get the IMAC video's
Hey guys,
Thanks for the help.
ki0qm ,
How do you do a reverse sharks tooth. If I remember correctly, a regular sharks tooth, from the 2005 sequence: pull to vertical, then at the top pull to 45 degree downline with 1/2 roll on the way down, then exit straight & level?
If that's the case then the reverse would be: pull to 45 degree upline, half roll to inverted, pull to vertical downline, pull to exit..
Correct?
EDIT: Watched the cirkus vid. after posting Nevermind
ki0qm ,
Correct?
