carb settings
I think the 2.5 on the LSN is correct, but you can probably go lower than 4 on the HSN... You will need to adjust that one based on your environment... anywhere between 2 and 4 is acceptable.
If you are having troubles keeping it running and/or starting there may be another issue.
On mine the idle screw (the one that prevent the carb from closing all the way) was in too far... that meant the smallest opening in the carb at idle was large.
Turn that screw out until your carb can close with a 1mm opening... this should be your idle condition.
If this isnt clear then let me know and I will post a picture to illustrate.
