Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > JetCat Turbine Direct Support
Problem with balancing lead - wrong polarity ? >
JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
Old 08-08-2013 | 04:01 AM
Gonzalo38's Avatar
Default Problem with balancing lead - wrong polarity ?
My turboprop came with a Jetcat 2S 3300 mAh Lipo battery.
I'm having problems when trying to charge it with the balancing option. I have tried three (3) different chargers and they all tell me that there is a problem with the polarity of the balancing lead. Is this a normal occurrence with the Jetcat batteries ? In order to solve the problem is just as easy as to change the wires from one end to the other ? Can this be done easily or do I need to buy a new balancing connector ?
Old 08-12-2013 | 06:42 AM
lxfly's Avatar
there should be the EHR balance connectors on Jetcat batteries.Just check your charger cable and the connection if polarity is the same.
Name:	60033_Sensorkabel_EHR_2S_3_Polig_025_mm_EHR_=_Kokam_Muldental_GmbH_Elektronik_564509994_300.jpg
