Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > JetCat Turbine Direct Support
Reload this Page >
Jetcat P80 issue with the Green LED
JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
Old 02-04-2008, 02:35 AM
raptorlogo
raptorlogo's Avatar
Default Jetcat P80 issue with the Green LED
Hello,
When I switch my radio on the green LED is blinking and when the turbine is connected the electric motor works intermittently.
It looks like SLOW DOWN mode but I check the radio learning, the 3 positions switch, everything is OK.
I already succeeded to start the engine but most of the time when I switch my radio on the green LED is blinking
Thank you in advance for your help.
Alain
Old 02-06-2008, 12:51 AM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Default RE: Jetcat P80 issue with the Green LED
Hi Alain,
Sorry for the late reply, my real job has kept me very busy lately.
My guess is that you Tx antenna is up and too close to the ECU while you are starting. The electromagnetic field from your antenna is so strong that is is causing trouble in the ECU. Just leave one segment up while starting and you will be fine.
Regards,
Old 02-06-2008, 06:50 AM
raptorlogo
raptorlogo's Avatar
Hi Matt,
Thank you very much for your quick answer and the good fix you gave me.
Everything is now running well.
Again thank you for your efficient customer support .
Best regards,
